How to Speed up windows XP booting
Hi, I have understood all of the explanation. However, I have one question that is How can open BIOS Setup Option?
You can try with pressing (Del) button or (F2) for latest version motherboard. However, some other key combination also exiest. First you need to know about your motherboard model then try to find it's own combination key to solve this question. Thanks
My motherboard is Intel GGC110. So I was able to enter into BIOS setup by pressing F2. There I did not found any Boot device priority menu. Please if help me again.
Hi Syedazharulislam
Check out this Techyv post " How to boot up the system fast?" which will be also helpful for you too.
