Can anyone help me on how to start and end session using PHP? I really don’t have an idea on how to do it. Is there any function to do this? Please help.
How to Start and End Session
Dear friend,
Session holds the session variable information and it is very easy to create session in PHP.
Before you create a session variable in PHP you need to start the session which is accomplished by below function.
Session_start();
You have to use this function before you create session variables.
Now you can create session variable and assign value to session variable as below.
$_SESSION[‘variable name’]=value;
You can retrieve and print session variable value as below.
$_echo “session variable value”.$_SESSION[‘variable name’];
Use can check variable value is set or not using isset as below.
If isset($_SESSION[‘variable name’]){}
If you want unset the session variable or free the session variable unset method is used as below.
Unset($_SESSION[‘variable name’]);
Example
<?PHP
Session_start();
If(isset($_SESSION['userid']))
$_SESSION['userid']=$_SESSION[' userid ']+1;
Else
$_SESSION[' userid ']=1;
Echo "Views=". $_SESSION[' userid '];
//Unset session using
//Unset($_SESSION[' userid ']);
