How To Stop Blue Screen Windows 7 In Simple Steps
Hi. I have recently started using Windows 7 and ever since I have been getting related to the blue screen error. How to stop blue screen Windows 7? Please reply ASAP. Thanks in advance.
Hi. To learn how to stop blue screen Windows 7, you can use a disk or USB to repair the error. Insert the disk in the system and shut down the PC. Next, start it again by pressing the power button. Instructions will appear on the screen which needs to be followed. Choose the language that you would want to appear and then click on next. Repair your computer and click on next. Then, select the startup repair option from the system recovery options and then follow the instructions. Alternatively, the problem can be solved by installing Windows 7 again.
Turn the computer on and insert the disc for the installation of Windows 7 and then shut the computer down. Next, start the computer again. After it begins, follow the instructions which appear on the screen. Enter the language to be selected on the install Windows page and click on next. Then, read the terms and conditions, accept them and click on next. Select the type of installation as custom and drive options as the place where Windows is to be installed. You can also change the partition and perform the formatting as required and then click on next.
Finish the installation, name the computer and set up the user account.
