How can I disable screen refinement in ACDsence Pro 8? I just install the new ACDsense Pro 8 photo software and the prog uses screen refinement which is not what I want. I have tried to see if I can stop this refinement but without success. Why is the prog using screen refinement? How can I stop it?
How to stop disable screen refinement in ACDsence Pro 8
It appears as though the default setting for the application is what you refer to as “screen refinement.” This is probably done because it is necessary for the application to be utilized in the manner you would like for the purpose of editing visual media and viewing it. If this is a problem for you, my suggestion would be to experiment with other editing software (e.g., GIMP [GNU Image Manipulation Program], Adobe Photoshop, or Serif PhotoPlus) to find an application that is more suitable.
