I find the PC Google fill annoying at times, and need it disabled especially since I am on a shared computer. Disabling this auto-complete feature had been suggested by a lot of computer blogs too.
I have been trying to disable it for days but cannot seem to get it successfully. Can anybody tell me how? I am using Google Chrome by the way.
How to stop pc Google fill in Chrome browser?
Hello friend it’s too simple follow these steps;
1: Click on the wrench icon which is located on the top right side of your toolbar.
2: Now select “Option” go to the “Personal Stuff” tab.
3: Under the “Form Autofill” uncheck this option.
Google Chrome is already equipped with this function so disable manually.
lee hung
75 points
Hunter,
If you are wanting to disable the "Autofill" option in Chrome it is pretty simple, just follow these steps:
1. On the browser toolbar click on the Chrome menu-
2. Now you will need to select "Settings".
3. Next choose "Show advanced settings".
4. Locate the "Passwords and Forms" section.
5. Uncheck "Enable AutoFill to fill out web forms in a single click".
Close down Chrome and restart it just to make sure all your changes take effect.
