How to stop plug-ins from popping out on my browser
how to stop plug-ins from popping out on my browser everytime i happened to open some websites? it's kind of annoying. i hope you can help me with this problem.
Hy Samara,
You may block popup for any website in your pc. Maximum user use Internet Explorer and Mozilla Firefox for use internet. Let I Explain for block popup
For Internet Explorer :
Open your internet explorer software (default computer browser of windows xp) and then select on “Tools “ then select “pop-up blocker” then select “Turn on pop-up blocker”
For Mozilla Firefox :
Open you Mozilla Firefox software and then select “tools” then “option” then select “content” tad and then mark “Block pop-up windows” and then press ok
Thanks
Hi Samara,
Instead of using Internet Explorer or Mozilla Firefox, I will advise you to try Google Chrome which avoids pop-up blocker automatically (See image below) and very easily.
If pop-ups have been blocked, you will see the “cross” symbol in the address bar.
1. Click the “cross” symbol to see pop-ups blocked.
2. If you like to see pop-up blocked page then click on the link for the pop-up window.
Here are the steps to download Google Chrome –
1. Download a free version of Google Chrome – https://filehippo.com/download_google_chrome/,
2. Download it,
3. Install,
4. Open the Chrome and start your surfing.
You’re right. It is really very annoying sometimes when a website makes so many pop-ups. Sometimes it is for the advertisement and sometimes it is required to complete what it is you are doing. Most of the pop-ups can be blocked by the web browser but sometimes they are not. A pop-up blocker that is built-in to the browser is activated by default so there’s no need to enable it.
When you install a web browser, the pop-up blocker is turned on automatically so that when you use it for the first time it automatically monitors the page of a website and blocks unwanted pop-ups. You will notice when a pop-up is blocked, it appears at the end of the address bar. To see if the pop-up blocker of your browser is turned on, follow these steps.
In Windows Internet Explorer 8, click Tools then point to Pop-up Blocker. You will see Turn Off Pop-up Blocker. This means the pop-up blocker component of Windows Internet Explorer 8 is turned on. See image.
In Opera browser, click the Opera menu at the top left corner then select Settings or press ALT + P. Select Websites from the left. Scroll down a little then you will see the Pop-ups section. You will see “Do not allow any site to show pop-ups (recommended)” is selected. This shows the pop-blocker is running and monitoring the browser. See image.
