How stop printing in vb6 after reaching a certain position ?
Hi experts,
How stop printing in VB6 is possible if I only want to print a portion of a page then go to another position and resume the printing process ?
Hi experts,
Hello Alicekdailey,
You can try playing with Printer properties in Visual Basic 6. It has properties like Print Bin and Print Size and others. Maybe those help you. Another thing is to try and set up a custom page in your 'Control Panel', then 'Printer Properties', after that set it up in your Report Form, preferably in Crystal Reports Editor.
Hope this helps.
This is a very good question. To solve this problem you must use Visual Basic. With this software you can solve the problem. I hope it will help you. You can also try C++. But Visual Basic is better than software. So, try this and I hope it will be helpful for you.
