How to stop spyware and protect my PC?
I am very worried with my PC and now there are so many pop ups appearing when I am connected to internet and even though I'm not clicking it, it appears always.
How can I stop it and what will happen to my PC?
Best Answer by Tony clever
Answered By 20 points N/A #89325
Hi friend,
If you have an internet connection and you are always connected, then you must have an anti spyware to protect your PC. The best way to solve this error is to replace the antivirus software with its new version if available. If there is no new version available, then go to command panel and then remove current Antivirus software and install an Antivirus that has anti spyware support.
If you have virus then remove it first. There is another reason why your computer is corrupted with virus. So you need to use another updated Antivirus and scan the full computer.
You also may use only a single anti spyware software, to protect your PC from spyware.
Answered By 0 points N/A #89326
The best thing you can do to avoid spyware is to have an Antivirus or anti-spyware installed in your computer. Millions of developers today want to develop their own spyware specially kids. New spyware aren’t detected by your Antivirus or anti spyware applications. You can trap their activity by installing a personal firewall to trap their activity. In that way you will be safe from spyware.
But the best of all is, you will be safe if you will be careful while using your computer. This is the best thing you can do for your computer to avoid spyware, trojans and virus infections.
Answered By 75 points N/A #89328
To prevent the spyware on your computer, use the firewall.  Go to the start menu ; click control panel where you can see the windows fire wall.  It can be helpful to your computer for defense or to protect the computer for any spyware.  Always update your software for the latest version or just visit the Microsoft Update. Go to the start menu and click the control panel you can see the windows update.
Adjust the Internet explorer security setting, by going to Internet Explorer and clicking the tools icon and then click the Internet Options and select the security tab. Download and install antispyware protection to help your PC from unwanted software or it can help to protect your computer.
