Hi guys, I have a python dictionary which I want to store in to MySQL actually its my project which I took from my friend and I need to do this within a week and I want to skip the long work and want to know is there any program or software which can do this or any online website where I can find easy solution to this.Please help me
How to store python dictionary in MySQL?Help
Happy to support you!
Actually, there are only few options to automate the process of storing Python dictionary data in MY SQL. According to the researches I have done so far, I can recommend you to use the software "mxODBC". This provides an easy to use, high-performance, reliable and robust conversion of the data in Python interface into ODBC compatible databases.
Follow this link to download the software.
