Hello experts,
How to successfully install NVIDIA osd program? I didn’t know some important measurements when installing software. Will you give me some over view on the proper installation process to prevent any error in the near future, for additional information I am using windows 7 starter. Thank you.
How to successfully install nvidia osd program?
Hi Greqory Gregory,
Nvidia will automatically install every feature that they have depending on your hardware capabilities. You may try to visit their homepage here: Â http://www.nvidia.com/page/home.html, they can automatically scan your computer specification so that nvidia will choose for you the proper software to install.
See the system requirements for the program click on install to start installing the software the program will guide you through out the installation and you will be able to install the software. This is as easy as 1 2 3 and you can do it your self. Also make sure you have a valid copy of software.
Smith Thompson
