Hi guys, I heard about gestures controls in smart phones but never used them and don't even know how to switch them on I mean how to switch on the gesture mode in galaxy S4 as I'm using it right now.Please tell me also how to use these controls and are these controls different in every smartphone or the same in all?
points
How to switch on gesture controls in S4?
Samsung Galaxy S4 is a great mobile phone that will help you use your smart OS to be operated just by moving your hands around the screen, not even touching it a single.
In order to switch on the gesture mode,
1. Tap down the top of the screen in order to open the “Notifications drawer”.
2. Tap “Settings” icon.
3. Tap “My Device” tab.
4. Scroll down to find out the option of “Motions and gestures” and tap it.
5. Turn on “Air gesture” to start the gesturing mode.
Now, here’s how you’ll use the mode.
If you’re on a webpage, move your hand up or down in front of the sensor of top-left corner.
If you’re watching images, just move your hands left and right to see next or previous photo of your gallery.
There are also many other moves that can be done quite easily. Just make sure gesture mode is turned on, and follow the options available.
