Hello All,
I want to sync android LG phone(LG Optimus Vu P895) with Mac for a week or so. I have tried it many times, searched net but I am unable to synch it with Mac. I have seen tons of Mac-LG Sync suggestions but none did the trick.
Please help me out as I don’t know much about Mac, if there is any application or tool or whatever I will buy it.
Please help.
Thanks
How to sync andriod lg phone with Mac
Dear Donna,
There are a lot of Synchronization software's that allow you to Sync Your LG phone with Mac.
Here are the best examples of such software's
SyncMate by Eltima Software: This software allows syncing LG phones with Mac regardless what operating system runs on the LG phone. It supports LG running Windows Mobile and LG running Android. It supports LG Optimus, LG Phoenix, LG Incite, LG Fathom, LG Eigen, and other LG phones. And requires Mac OS X 10.6.6 or higher
SyncMate LG sync for Mac is here try it out!Â
The Missing Sync for Android: This allows syncing Mac to any Android phone
The Missing Sync for Android for Mac
Both software's allow the transfer of files fast with a USB cable
Hello, Donna
Hope you are fine. However FoneSync is an easy way to synchronize your LG phone with your Mac. It allows you to synchronize calendar contacts,entries  just by a one-button-click.
Now you can synchronize your LG phones with Mac OS X before which was not possible before.
      FoneSync has an option for cleaning and sleeking interface and it is easy to use.
      FoneSync is available in English, German and French language.Click here for FONeSYNC.
      You may see the video results in better understanding.Click here to get the video.
     Hope you will get your answer.
