How to sync folder osx lion? The company told me that we will be going to use mountain osx lion, I just want to ask some information regarding syncing folder files in mac os. There are some times that we have to sync the folders or merge two folders, how can I possibly perform it in mac os?
Waiting for your support, thank you.
You can sync folder in Mac os using “Sync Folders Pro for Mac OS X 10.7-10.8”. Using this software you can sync folders on your Mac. You can use various modes of synchronization to sync folders. You can also synchronize external drives which are connected to your mac. Moreover you can sync across a network. You can set “Auto Sync” option to check the changes. You can sync folder to folder every files or missing files and compare folders.
Hi Nelson.
You want to sync folder OS X lion? I shall suggest you to use Sync Folders Pro for Mac OS X 10.7-10.8. This is a very useful software. You can sync more than two files with this. This is a special software for mac. This synchronizes in 6 different modes. You can also sync any external drive like pen drive, dvd etc using this. It keeps the previous work history what will help you a lot. This also has a very powerful filter option. There is also an option of auto sync. You can use this too.
Thank you for your question.
