How To Sync Google Calendar With Outlook 2013 Using Simple Stepss
Hi. I have recently started using MS-Outlook. I want to learn how the Google calendar can be synced with Outlook. How to sync Google calendar with Outlook 2013? Please reply ASAP. Thanks in advance.
Answered By 90 points N/A #112413
Hi. To learn how to sync Google calendar with Outlook 2013, first, export the calendar by logging in to the Gmail account and then select calendar. Then, select my calendars following which click on settings. Then, export the calendars and select a location where the extracted file is to be extracted. Unzip the file after you go to the location, right-click on it and select the extract all option. Next, import the calendar to Outlook by clicking on Outlook on the desktop and click on calendar. Then, click on the file, open and export option and finally select the option to import/export.
Then, select the .isc or calendar file and click on next. Go to the location where the extracted file has been saved and select the one ending with gmail.com. Then, click on OK. Select the import option and go to the Outlook calendar. You will now be able to see the events of Google calendar there.
Hope we helped.
