Hello experts,
How to sync iPhones with qnap? I would like to know if there are way to sync the contacts of iPhones and with other email address, phone number and more information to qnap? I just need some information regarding this issue and I am willing to listen to your advice. Thank you.
How to sync iPhone with qnap?
If your QNAP NAS model comes with an FTP server, you can set up this FTP Server and use PhotoSync to connect to the FTP server to transfer your photos to the NAS.
The only necessary requirement for PhotoSync is that the FTP user must have write access to the directory which PhotoSync will access.
Hi Danield,
You can synchronize the files, photos, contacts from the iPhone through QNAP.
The steps to perform the sync is as mentioned below:
1) Create a user account on the QSync users
2) Install the QFile for the mobile devices
3) Launch QFile in the system
4) Click 'Settings' on the right side of the screen
5) Click 'Auto upload from photo gallery', Click 'Setup Now'
6) Select the folder and Click 'set up manually' to set the path
7) The files will be synced to the 'camera uploads' in the system
