How to sync Lotus Notes Outlook
I need Lotus Notes (developed by IBM) and Outlook (a Microsoft product) to be sync so that my messages, contacts and calendars can be exported to Outlook. Please suggest on how to sync Lotus Notes Outlook.
Hi Silver,
Lotus Notes is developed by IBM and Outlook is a Microsoft product. But you can easily sync your notes, contacts and messages from Lotus to outlook by using the Microsoft tool called Outlook 2003/2002 Add-in: Notes Connector. So far I know it is the quickest and safest way to sync your Lotus Notes to Outlook. Download this add-in from Microsoft Download Center and install on your PC. Then Open Outlook, Click Tools-Account Settings-Email-Select New-Other-and then select "Microsoft Office Outlook Connector for IBM Lotus Notes Domino." Then click next. Your Outlook will restart automatically and you will see that it syncs all there from Lotus.
Notifications
