How to sync mdaemon calendar Google in Windows 7
Hello IT folks. I just recently found out thatt you can sync mdaemon calendar google. How is this done? Is there an FAQ on this? Please point me in the right direction
Hi Cyril,
How are you? Hope you are doing well.
I would say you cannot sync mdaemon calendar with Google. You are using some client software and Google does not allow you to sync with the data with the client. But researches are going on because some rumors say that can be done. I will let you know if I get any clue one the same.
Hope I have pointed you to the right direction.
Good day!! Thanks for question posting on techyv.com!
Desktop iCalendar is a customizable desktop calendar which can sync with Google Calendar, Yahoo Calendar and CalDav servers… The program adds calendar, events, to-do list and weather on your desktop. It allows you to edit your calendar offline and sync with remote when network is available. So you can edit your Google calendar offline, and share.Have a nice day.
Thanks
