Hi guys,
How to sync Samsung phone to lotus notes?
I got a Samsung wave 2 mobile phone and was thinking how can I sync my contact list to lotus notes application?
I hope you can provide the most important information needed for this kind of situation.
Expecting some help, thank you.
How to sync samsung phone to lotus notes?
Hi Davis Millers,
You can sync your Samsung phone to lotus notes by using a software called desktop mirror.Â
Desktop mirroring is a software by which you can easily sync your Android phone which in your case is the Samsung wave 2 with Lotus notes.
There are also many options available for you to customize your synchronization.
I hope you find the solution to your problem.
Hi Davis Millers,
You can sync your Samsung phone to lotus notes by using a software called desktop mirror. Desktop Mirror is software which is very easy to use and you can easily sync your Android phone which in your case is Samsung wave 2 to lotus notes and you can also customize various settings of synchronization.
I hope you find the solution.
Have a nice day.
Hi! I understand your problem and I'd be glad to help you.
Lotus Notes is the client side of a client – server, collaborative application developed and sold by IBM Software Group. Integrated desktop client option for accessing business email, calendars and applications on an IBM Lotus Domino server.
If your phone is android based then you just need a software called LivePIM that lets you sync your contacts from your phone to Lotus notes.
