James0229
Posted on - 08/19/2011
I downloaded from Net new game, application and a software updateThen i tried to install these programs on my PC. But during installation an error occered.This job made my system nstable.Then i wanted to make it stable.But i never made system restore earlier.So please guide me step by step to make this restore
How to System Restore to Undo Changes when Problems Occur
I'm not sure what exactly is happening in your computer but try these few information. These might help you fixed your windows.
If your windows is still running, and you think it was your game application that caused the problem you can remove that application in the Add or Remove Programs.
Do you receive error messages during starting up your computer? If so, run System Configuration Utility and turn off files or services mentioned in the error message.
Also try the Last Known Good Configuration tool to restore back the good settings of your windows. Last Known Good Configuration can be accessed by starting the computer and press F8 key in your keyboard when windows starts. In the Windows Advanced Options menu, choose Last Known Good Configuration (your most recent settings that worked).
Hope at least one of these could help you.
