How to take the opportunity to turn time limit off for pc?
It is truly necessary for me to turn  time limit  off for my pc. I know there is an option to turn it off, but do not know the way. I want to take the opportunity.
Can anyone help me in this regard?
Best Answer by warren todd
Answered By 0 points N/A #140453
It is very easy to turn someone's PC by giving time limit.
1. Go to the start menu of  windows operating system. Click on start.
2. Go to Run option. (Click on all programs then click accessories then find Run and click on it.
3. After clicking on Run, you will find a  large empty search box. Type shutdown then give a single space then type -s then gives a single space then type -t then gives a single space  give after how many seconds you need to shutdown your PC.
4. Now click ok on that run box. You will be popped upped to shutdown your PC after how many times. Click ok and wait.
Thanks & Regards
Baishnab Bihari Tripathy.
Puri
Answered By 0 points N/A #140454
It is very easy to turn someone’s PC by giving time limit.
1.     Got the start menu of windows operating system. Click on start.
2.     Go to run option (Click on all programs then click accessories then find Run and click on it) in window 7.
3.     After clicking on Run, you will find a large empty search box. Type shutdown then give a single space then type –s then give a single space then type –t then give a single space then give after how many seconds you need to shut down your PC.
4.     Now click ok on that run box. You will pop up to shut down your PC after how many times your window is going to shut down. Click ok and wait.
