How to take a snapshot using keyboard?
Hello experts,
I have a laptop. But I am not be able to take any snapshot using this laptop keyboard. So I am going to use an alternative software for taking snapshot. It is very needed to me.
So the question is that which software can I use for this solution?
This information will help me very much.
Best regards,
Mazharul Islam
Best Answer by Laique Ricad
Answered By 0 points N/A #163418
Greetings Mazharul! My suggestion to you is the SWB Capture, this  is a software that Captures images of any window or the entire desktop via drag and drop.
Save the images to the clipboard, to a named file, or auto save into the directory of your choice.
Supports BMP, JPEG, and GIF formats. Freeware.
And you can download It here!
Answered By 5 points N/A #163419
Hello Mahzharul Islam,
You will be able to take snapshot from your laptop keyboard by pressing PrtSc key. So you don’t have to use any software.
 If you are using windows 7 you can get built software which is in accessories there you can take your snapshot.
You will enjoy your taking snapshot.
Answered By 0 points N/A #163420
Mazharul Islam
You can try this step for take a snapshot
  1. Press “Print Screen SysRq” key from the keyboard.
  2. open Ms paint option, it found at Star > All Programs > Accessories > Paint
  3. Press Cltr+V,
  4. Save it at your own directory,
Or
You can take snapshot using this software. Click the for download software.
Answered By 0 points N/A #163421
To take a snapshot please follows my instructions.
1. Go to your positions which snap will you take and then press prtsc from keyboard.
2. Then go to pain option by using your start button, then accessories and then pain.
3. Simply just paste it using ctrl+key.
4. Then press ctrl+s to save the snap. That's all.
Answered By 0 points N/A #163422
You can take snapshot by using Print Screen SysRq key.
It takes the snapshot of the window which is open.
1. Just press SysRq key.
2. You can snapshot MS word or paint or another application software.
3. It takes screenshot ff entire screen.
If you want to use alternate software for snapshot
Then use Gadwin Web Snapshot.
Thank You
Answered By 0 points N/A #163423
Hello Mr. Mazharul.
You don't need to use any extra software's to take a snapshot of your laptop.
You can do this operation using your laptop keys. Just press the 'prt sc' on your keyboard whenever you want to take a snapshot. When you press the key,the snapshot will be automatically taken. To find this snapshot,click on your start button.
Then click on 'all program's', click on 'accessories' option. Select 'paint'.
There,press 'ctrl+v' and your snapshot will be pasted on the folder.
Then you can save this file on your desired location.
Thank you vaia for your question.
