How to test if the heat sink is functional
Posted on - 02/06/2015
I have a Pentium 4 computer that was previously overheated and shut down, however after checking for loose connections on the processor, It was established that the heat sink was not as effective. is there a way that one can establish if the heat sink has a problem and rectify.? Do I need to change the heat sink?
