Posted on - 12/03/2011
How to test my hardware before buying
First time when i buy pc it was assemble to my PC Sales and Services. They don't really test it they just assemble and onceÂ
it's done all you have to do next is to install OS. So far based from my experience there will be no way the vendor theyÂ
gonna test their product before you buy it. Anyway, this parts are being tested on the Quality Control before they releaseÂ
it. There will be tendency of factory defects actually it's .01% out of 1Million there will be 1000 or 10,000 defectiveÂ
parts. Most probably defective parts are will be damage in more than a year or after the warranty periods. I suggest youÂ
should find quality parts on CPU to make sure it would last i will give you an example like KINGSTONE RAM this has aÂ
lifetime warranty although is quite expensive compare to the other brand but it really works to last.
Thanks,
Tony Stevenson.Â
When you purchase a new computer, you can test its performance using online diagnostics tools, most of which you can get and download for free. I will recommend that you visit the following site to download a tool that you can use to test the performance of your PC:
You can get tools that you can use to test the performance of the CPU, memory, the disk drive, network adapters, optical drives, the battery and many other hardware components of your computer that you may want to test. You will be able to determine the speed at which your computer operates, and also make it easy for you to troubleshoot any problems that you may be having on your computer
Regards
Thompson Locker
