How to test voice changer- Plugin requirement?
I have a video clip with normal human voice. I want to change that voice to alien voice. I want to select voice changer software by testing. Please tell me how to test voice changer with plugin requirement. Thanks
Answered By 0 points N/A #193383
Hello Holari Traun, I can suggest one way you can use in order to change the voice of your video to add alien effect, please follow the steps listed below: 1. Convert your video into an mp3 file, preferably using this software: http://www.xilisoft.com/video-converter.html 2. Now download this software: http://www.tucows.com/preview/422671 3. Add the audio effect of your desire to the mp3 file of the video you made, refer to the tutorial notes of the software if you have a problem. 4. Mute the audio of the video, and add a second layer of audio, that is the one you have added the effect to. The 4th step can be done through the use of Windows Movie Maker which is pre-installed in the Windows, if it is not there, download from: https://support.microsoft.com/en-us/help/18614/windows-essentials
