Luigi Molly 10 points N/APosted on - 03/22/2012
Hello
I was just wondering if it was at all possible to tether my motorola atrix (which has a 2gb data plan with at&t) to my apple ipad? I want to have access to the internet with my ipad when im not in wifi range.
Please let me know if there is any possible way to do this!
The most possible way to solve your problem is to call apple. Moreover, you need to know that there are several websites which offer different types of prize. Check this video
I can provide you a site wherein a video is shown on how to tether Motorola Atrix. But if you really need to tether your Motorola Atrix to your iPad with correct configuration just to avoid problem in the future, first, you need to call Motorola for the phone support. There will be some configurations to be done so that it can be tether with your apple iPad and also you need to call Apple for support just to make sure configurations that will be done will work for your iPad.
1....
