How to thunderbird recover emails?
Hi all,
I have accidently deleted my two very important business emails from mailbox and trash folder in mozilla thunderbird.Now,i wish to retrieve them.Please any genius from techyv, provide me tips and tricks to thunderbird recover emails.Your help will be highly appreciated.
Answered By 5 points N/A #186884
Good day Jeffrey
For the following steps to work you must make sure that you didn`t compact your folders.
If your hidden folders is not open do this.
 In windows 7 open the explorer, go to organize, folder and search options, click on the view tab and tick show hidden files and folders and drives.
Then go to explorer, click on C: (in my computer), click on your Windows username, then App data,Thunderbird, then profiles, then profile name.Launches the inbox file without the .msf file extension in a text program like Notepad.
Opening files can take a few minutes.In the picture below is X-Mozilla-Status: is 00009.
Set the X-Mozilla-Status to 0.
Save the file and open Thunderbird. Your deleted mail should be in you inbox.
hopefully this steps will get your mail back.
