How to add the Unread Mail folder in outlook?
I installed Outlook on my PC so that I can check up with my e-mails regularly. But I cannot locate the Unread Mail folder. I am not able to find the unread mail folder. Do help me with locating the Unread Mail folder in Outlook.
Best Answer by
Answered By 0 points N/A #329154
Open Outlook by typing ‘Outlook’ in the Search Bar of the Start Menu, and then clicking on the Microsoft Outlook to open it. On the left side of Outlook, right-click on ‘Search Folders.’ Now, click on ‘New Search Folder.’
A new dialog box will appear. Select ‘Unread mail’ and then click on ‘OK.’
The Unread Mail Folder will be added below the ‘Search Folder’ on the left side of the Outlook 2007 main screen.
