How To Bartender Mix Genius Recipes Points For The Phone.
Has anyone tried to get 7000+ points on bartender mix genius recipes point? Does anyone have a solution for this? Please help me to achieve this?
Here are some hints which help you to gain 7000+ points.
For a better score, also combine vodka and cranberry juice with include some other mixes to get almost 6000-8000 score achieve.
Also mix vodka, cranberry and lime juice, ice. And make sure that vodka adds more and lime mix in less quantity.
If you did all this properly then, the bartender will hit Gitar and also play a rock music.
If you play “Bartender Mix Genius” on your Android phone, here’s how to get some high points aside from the 7,000+ points you want:
To help you with other tricks on playing the game, try watching some of the Bartender Mix Genius Videos.
