How To Change The Google Screen
I want to change the Google Screen. Is it possible to customize it rather than having a standard screen? What are the steps to do so?
Yes, it is possible. Customization is the trend; you’ll hardly find anyone having the default settings. Just follow the simple steps written below:
1) Click on the Google Chrome icon.
2) Click on the pencil in the bottom right.
3) Click on Chrome Backgrounds.
4) Select the type of background you want in the Collections field.
5) Select from the available options.
6) Click on Done.
Your home page is according to your wish now!
If you want to use Google Chrome but you want to customize the home screen, it is now possible with the latest version of the browser. In the latest version, you can now add a theme in the home screen. In the home screen, you can now change the background of the browser with different images.
To try it, download the latest version of Google Chrome and install it. Once installed, start Google Chrome then in the home screen, click the pencil icon at the bottom right corner of the screen to customize the page then select “Chrome backgrounds”. In “Select a collection” screen, select the category you want for the background.
There are nine categories to choose from: Landscapes, Textures, Life, Earth, Art, Cityscapes, Geometric shapes, Solid colors, and Seascapes. Select the category you want then pick an image on the next screen and then click “Done”.
