How To Connect Computer To Wi-Fi Network?
Hey a everyone! I have a desktop for which I use an Ethernet cable to get the internet access. But, I want to have a Wi-Fi connection on it for the rare occasions to use when I am on the move. So, how to connect computer to Wi-Fi?
Answered By 10 points N/A #298356
Below are the techniques that you can use to have the internet connection wherever you go:
  1. A USB-to-Wi-Fi Adapter:
It is an easy-to-use method that is also budget-friendly. It is like a tiny dongle that you can connect to the computer’s USB port. It has a built-in Wi-Fi radio that lets the system to connect to the network. It is available for as little as $10 on many e-commerce websites. You can insert it into one of the spare USB port for all time and can also take it with you to connect to any computer wherever you go.
  1. Install an Internal Wi-Fi card:
You can insert a dedicated Wi-Fi card into the PCI Express slot or any other similar slot. It will need you to open the system’s hardware. You can buy it for a price of $15 to $35 on online sites. However, before buying, make sure that you are comfortable installing it on your own and that your computer has a free slot. The advantage of this is that it has better signal strength and long lasting.
