How To Connect DirecTV Box At Home?
I have got a DirecTV satellite installed outside my home, but due to some emergency at that time, the box could not be installed. Is there any way to do it now? If yes, how to connect DirecTV box manually?
To fix the DirecTV box is a much simpler process that needs no technical knowledge.
Simply, connect the coloured cords on the back of the receiver box to the same colour port on television.
Connect one end to the ‘In from Antenna’ port on Television, and the other end to the ‘Out to TV’ on the back of DirecTV receiver. Now, go to channel 3 or 4 to watch.
Simply plug in the ends of the cord to the HDMI ports on both the devices.
It requires separate cables for sound and video. Connect the cords on the receiver to the matching strings on the TV. Plug in green, blue, and red connectors for video, and white and red cables for sound. Finally, set the quality to 1080i or 720p.
