How To Convert 0x2e To Dec?
Hello, I am a student; I don’t know how to convert 0x2e to Dec, please help me with the steps to be followed to convert 0x2e to dec. Thank you.
Hello people, if you are confused with the question of converting 0x2e to Dec, don’t worry, it’s easy to, follow the below steps to convert any hex number to dec.
The hexadecimal number system is the base 16 number system has 10 numbers and 6 symbols in it, they are 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, A, B, C, D, E, F, where A = 10, B =11, C=12, D= 13, E= 14, and F= 15.
Before we get into the technique, you need to know that the numbers which start with “0X” are known as hexadecimal numbers. According to the statement mentioned before, we can say that “0x2e” is a hexadecimal number. The hexadecimal number system is a base 16 number system.
We need not consider 0X while converting 0X2e to Dec, because it is used only to indicate that the given number is a hex value.
• Step 1: Given number to convert is 0x2e, so first we have to find out the value of the symbol “e.” According to the hexadecimal number system value of “e= 14”. Hence, you have to consider “e” as 14.
• Step 2: Find out the last digit, I.e., on to your right-hand side and multiply it with 1. Similarly, find the second last digit and multiply it with 16, next, multiply the third digit by 16 × 16, and so on.
• Step 3: Next, add all the products of each digit, after multiplying them with the numbers to get the answer in a decimal number system.
• Now, using the above steps, we will try to convert 0x2e to dec:
E × 1 = 1e I.e., 14 ×1= 14 (last digit multiplied by 1).
2 × 16 = 32 (second last digit multiplied by 16).
14 + 32 = 46 (adding up the products after multiplication).
• Hence the decimal value of 0X2e is 46.
These steps can be used to convert any hexadecimal number to a decimal number.
Notifications
