How To Convert Bytes To Kilobytes Online?
I am handling a lot of data on my computer. But the memory size is being shown in bytes only. I want to see the size in kilobytes. How can I convert bytes to kilobytes so that I can get more information about the memory?
Answered By 0 points N/A #299261
Byte conversion has a simple rule. Since all the data stored in computer is binary every unit is counted in the power of 2. Hence a common multiplier is conventionally set as 10th power of 2. Following are the same conversion rules for binary data.
  • 8 bits = 1 byte
  • 2^10 bytes = 1 kilobyte
  • 2^10 kilobytes = 1 megabyte. And so on.
Hence to convert bytes into kilobytes we need to divide the number by 1024 because 2^10 is equal to 1024.
You can also use online converter or Microsoft binary calculator for conversion.
