How To Convert Eps To Font Online
I have my images in .eps format. But my designer says there are the font styles I had prescribed. How do I convert eps to font? Do I need a software? Can I do it online?
EPS stands for Encapsulated PostScript. Designers use this file format to make new font styles. Such files cannot normally be viewed using image viewers. To use them as fonts they converted to other formats like dfont and TTF. TTF stands for True Type Font. This format is used in Windows OS and Mac OS. It is very popular.
To convert EPS to TTF online –
Visit https://onlinefontconverter.com to convert the eps file online. Upload the file on the server and wait for the website to convert it to TTF format. After that, you can download the converted file.
To convert EPS to TTF offline –
Install a software called as ‘Free TTF converter.’ Run this software on your computer and follow the instructions to convert your EPS file to TTF.
