How To Copy Some Text On My Phone
I want to copy some text on my phone. The problem is it is not a message or something like that. Is it possible to copy it?
Yes, it is possible to copy any written stuff on your phone. Just follow the steps given below:
1) Go to Google Play Store.
2) Install Universal Copy app.
3) Click on the icon.
4) Enable Universal Copy, if it shows an error then go to step 5) else go to 9).
5) Go to Settings.
6) Go to Accessibility.
7) Select Advanced Features.
8) Tap on Universal Copy. Enable Universal Copy now.
9) Open whatever you want to copy.
10) Tap on the screen; this will make a margin on the screen.
11) Tap on the text you want to copy; this will copy it on the clipboard.
Text copied now!
Notifications
