How To Create An Exchange Certificate Request?
I need an SSL certificate from my Exchange 2016 server for a certification authority. Can anyone tell me the process to create an Exchange certificate request.
Creating an Exchange certificate request using EAC –
1 – Open Exchange Admin Centre.
2 – Go to Servers -> certificates.
3 – Select your server and click on the + icon on top.
4 – Choose the first option.
5 – Enter a name for your certificate.
6 – You need to choose a server here.
7 – Choose domain names to be included in the certificate.
8 – Enter the required details.
9 – Enter a valid UNC path.
10 – Click finish.
Method 2 – Using Exchange Management Shell
1 – Open PowerShell.
2 – Use this syntax –“ New-ExchangeCertificate -GenerateRequest -RequestFile <FilePathOrUNCPath>\<FileName>.req [-FriendlyName <DescriptiveName>] -SubjectName [C=<CountryOrRegion>,S=<StateOrProvince>,L=<LocalityOrCity>,O=<Organization>,OU=<Department>],CN=<HostNameOrFQDN> [-DomainName <Host1>,<Host2>…] [-BinaryEncoded <$true | $false>] [-KeySize <1024 | 2048 | 4096>] [-Server <ServerIdentity>]”
Make the changes in the field marked with <…> according to your suitability.
