How To Create The Best App?
Nowadays everyone is interested in mobiles, and mobile phone applications in place of websites. So, how can I create a mobile app, which suits the new and developing operating system? To be the best application, do I need to know about the device and operating system in which it will run?
Answered By 0 points N/A #319503
Every operating system has its, own patterns and rules. Your app should be built in a way, that it should work in the present version and also in the next coming models. The release of the beta version of the app helps to check the operating system used in your app. To be compact with the device, you should make a responsive design for the app. You should follow the development flow of an operating system and the mobile. The type of operating system in which you think your website should run will also add some features in your app.
