How To Display An Image Of My Choice
When I open my computer, and it asks me for the password, it shows an image box below which it asks for the password. Is it possible to display an image of my choice in that area? If yes, then how?
I believe you are using a Windows machine. If so, Windows gives us plenty of customization opportunities, and Account image is one of them. Here are the steps:
1) Click on the Windows button.
2) Click on Settings.
3) Go to Accounts.
4) Go to Your Info part.
5) Go to Create Your Picture.
6) Here you’ll be shown two options
• Browse
• Camera
7) If you chose Browse in step 6), it will prompt the File Manager.
8) Select the image you want.
9) If you chose Camera in step 6), the webcam will turn on, and you will have to take a picture.
10) Now the image chosen will appear with margins; you can crop and adjust the part you want.
And you are done!
