How To Display Excel 2013 Developer Ribbon On Toolbar?
Hello everyone, I want to know the steps to display the Excel 2013 developer ribbon on the toolbar. Please provide me the sets for this setting. Thanks in advance for the help.
Step1
Open Outlook 2013. Click on the file menu, and choose the select option from the drop-down menu.
Step2
Choose the developer option and check it under the main tabs of the customize ribbon, click OK.
Step3
After this, the developer options will appear on the toolbar. All the developer tools like add-ins, code, controls will be present.
For users with older Microsoft Office Excel 2007, showing the “Developer” tab is pretty much the same. In Microsoft Office Excel 2007, click on the Office button and select “Excel Options” at the bottom. In Excel Options window, in “Popular” on the left pane, check “Show Developer tab in the Ribbon” then click “OK.”
This should now display the “Developer” tab together with the other tabs in Microsoft Office Excel. Now, if you want to add a function or command from the Developer tab into the “Quick Access Toolbar” located on the top left corner of the screen, repeat the same steps then in Excel Options window, select “Customize” on the left pane.
On the right, under “Choose commands from” column, select “Developer Tab” from the dropdown list. Now, from the available commands, select the command you want to add to the Quick Access Toolbar and then click “Add.”
When you are finished adding commands, click “OK.” The commands you added should now appear in the Quick Access Toolbar.
