How To Do Quick Heal Antivirus Upgrade
I have installed the quick heal antivirus on my computer. It has been a while, and I was wondering if there are any upgrades that I can do to my antivirus. I do not know how to do this. How to do quick heal antivirus upgrade?
Answered By 0 points N/A #324460
Upgrading your antivirus is pretty easy. For the first part of your question, your antivirus software does update itself from time to time with automatic updates, so you don’t have to worry about it.
As far as upgrading your antivirus is concerned, you need to go to the website of the antivirus and see if a newer version is available. If this is the case, you need to download the file. Once you download the file, start the auto-run program and click on the upgrade now.
