How To Do Toshiba Windows 7 Upgrade On My Laptop.
I have a Toshiba laptop with Windows Vista and I want to update it. How to do the toshiba windows 7 upgrade. Does anyone know?
The answer to your question is simple, just follow the steps here to get Windows on your Toshiba laptops.
Recommended method because it will assist you in the installation.
If you have Microsoft Windows Vista on your computer and you want to upgrade to Microsoft Windows 7, yes, it is possible. Windows Vista is upgradable to Windows 7 but what they normally recommend when shifting to another higher operating system is not to upgrade but to do a clean install. Upgrade and clean install are different.
With upgrade, you simply run the upgrade installer and follow the instructions until the operating system is upgraded. Your settings and applications will remain intact and usable on the new operating system. Nothing is removed from the computer. With clean install, everything has to be done from scratch. It includes formatting your system drive, installing the new operating system, and installing all your applications back.
If you want to do an upgrade, you simply need to download or purchase the upgrade installer from Microsoft for the Windows 7 operating system and run it on your computer just like an ordinary installer. It will upgrade your operating system from Windows Vista to Windows 7. You just need to follow the instructions just like when installing a fresh copy of Microsoft Windows.
