How To Download Microsoft Office 2007 64-bit?
I want to download Microsoft office 2007 64-bit on my system. I have 32-bit setup. I want to know how to download 64-bit software.
It doesn’t matter that you have the 32-bit version or 64-bit version. A 32-bit version is compatible with the 64-bit version. You need to worry if you have a 32-bit system and a 64-bit version. While if you want to download a 64-bit version, either you can download from Microsoft’s official website or you can just simply google it and you will get various links to download. Use anyone, choose a 64bit option, and download it.
If you are looking for 64-bit Microsoft Office 2007, unfortunately, there is none. Microsoft Office 2007 is available only in 32-bit version but it runs fine on 64-bit Microsoft Windows. If you want to install Microsoft Office 2007, check that your computer meets the requirements. Microsoft Office 2007 supports Windows XP Service Pack 2 or higher, Windows Vista, Windows 7, Windows 8.x, and Windows 10.
It requires 500 MHz or faster processor, 256 MB RAM, 2 GB free space, 1024 x 768 screen resolution, and Microsoft Internet Explorer 6.0 or higher (32-bit only). The 2 GB hard drive space requirement is the standard size to install the entire package but the final amount will still depend on which features you will install.
According to Microsoft, Microsoft Office 2007 and later versions are verified to be compatible with Microsoft Windows 10. Versions earlier than that like Microsoft Office 2003 and older are not certified to be compatible with Windows 10 but might work using compatibility mode.
