How To Download Microsoft Office 2010 For PC?
I am a student, and I want to download Microsoft Office 2010 for pc, but I am not able to understand the difference between 32 and 64-bit. How to get through this confusion?
32-bit and 64-bit are two versions of your operating system. They enhance your system’s performance. The heavy software is not properly supported by a 32-bit version but is supported by a 64-bit version. It doesn’t matter that you have the 32-bit version or 64-bit version. A 32-bit version is compatible with the 64-bit version. You need to worry if you have a 32-bit system and a 64-bit version. While if you want to download Microsoft Office 2010 for pc in a 64-bit version, either you can download from Microsoft’s Official website or you can just simply google it and you will get various links to download. Use anyone, choose a 64bit option, and download it.
The “32-bit” and “64-bit” thing in computer refers to the hardware or the computer itself without the operating system and software. It particularly points to the motherboard where all devices are installed and connected. If you want to know if your computer is 32-bit or 64-bit, check your motherboard. On 32-bit computers, you won’t find “32-bit” printed on the motherboard.
But if your computer is 64-bit, you will find without quotes “64-bit” printed on the motherboard. If you don’t see this, that means your machine is 32-bit. Other terms used are “x86” for 32-bit and “x64” for 64-bit. If your computer is 32-bit, you need to install the 32-bit version of the program because it doesn’t support 64-bit.
If your computer is 64-bit, you can install either the 32-bit or the 64-bit version of the program. If the program is available in 64-bit, it’s just right that you install the 64-bit version. The Microsoft Office 2010 suite is a version of the Microsoft Office series of productivity suite designed for Microsoft Windows.
Codenamed “Office 14”, it is the successor to Microsoft Office 2007 and the predecessor to Microsoft Office 2013 released to manufacturing on April 15, 2010. It was made available to the public for retail and online purchase on June 15, 2010. Its development began in 2006 before Microsoft Office 2007 was released.
It supports Windows XP Service Pack 3, Windows Vista, Windows 7, Windows 8.x, and Windows 10 including Windows Server 2003 until Windows Server 2012. This is the last version of Microsoft Office to support Windows XP, Windows Vista, Windows Server 2003, and Windows Server 2008 because none of these operating systems are supported in Microsoft Office 2013.
Microsoft Office 2010 also marks the debut of Office Online, formerly called Office Web Apps.
