How To Download Microsoft Office 2013 For Pc?
I am a student, and I want to download Microsoft Office 2013 for pc, but I am not able to understand the difference between 32 and 64-bit. How to get through this confusion?
32-bit and 64-bit are two versions of your operating system. They enhance your system’s performance. The heavy software is not properly supported by a 32-bit version but is supported by a 64-bit version. It doesn’t matter that you have the 32-bit version or 64-bit version. A 32-bit version is compatible with the 64-bit version. You need to worry if you have a 32-bit system and a 64-bit version. While if you want to download Microsoft office 2013 for pc in a 64-bit version, either you can download from Microsoft’s official website or you can just simply google it and you will get various links to download. Use anyone, choose a 64bit option, and download it.
Before installing Microsoft Office 2013, make sure your computer meets the requirements. Microsoft Office 2013 supports Windows 7, Windows 8.x, and Windows 10 including Windows Server 2008 R2, Windows Server 2012, and Windows Server 2012 R2. It requires 1 GHz or faster processor with SSE2 support, 1 GB RAM for 32-bit and 2 GB RAM for 64-bit, and 3 GB free space.
Some features may also require you to install Microsoft .NET Framework 3.5, 4.0, or 4.5 so make sure to install them. For a little history, “Office 15” is the codename given to Microsoft Office 2013 and is the successor to Microsoft Office 2010 and the predecessor to Microsoft Office 2016.
This version is suitable for IA-32 and 64-bit systems and includes support for extended file format, user interface updates, and touch function. Mainstream support for Microsoft Office 2013 ended on April 10, 2018 while extended support ends on April 11, 2023. Its development started in 2010 and ended when it was released to manufacturing on October 11, 2012.
If you want to try Microsoft Office 2013, you need a Microsoft account to get it. Go to the Microsoft account portal then log in. In “Services and subscriptions”, look for “Microsoft Office 2013” then click “Install”.
