adeleon
Posted on - 06/01/2020
Hello, I recently finished installing office 365 outlook 2013. But I want to add some features or applications with Outlook 2013 such as Map, Zoom, etc. How can I add these features and help me with the steps to perform this?
How to enable Add-ins while “setup office 365 outlook 2013”?
Enabling the Add-ins feature will make the life of the user much comfortable. Now let me explain the steps to perform this configuration. Office Add-ins is one of the best features in Outlook as it makes it user-friendly for users to access most of the applications within the Outlook application. For example, if you want to schedule a meeting through a Zoom application, opening the application and copying the meeting link would be a tedious process. But with the help of the add-in feature, which is available for zoom, a single click will schedule the meeting and the URL would be copied.
The steps are as follows:
- In the Outlook, click Home tab, then click on Get Add-ins
- On the Add-Ins for Outlook page, browse the add-in which you want to add it. When you find the add-in you want, see if it for free or purchase one.
- Then select “Get it” to install the add-in.
- When the add-in is installed, go to “File -> Manage Add-ins or Manage Apps” to make sure the required add-in is turned on. You can select “Find more add-ins for Outlook at the Office Store” for more add-ins.
