How to enable Exchange 2010 outlook anywhere?
I am using Exchange 2010 server. I need to access Outlook Application, but to do that, I need to enable Outlook Anywhere. How to enable Exchange 2010 Outlook Anywhere?
Method 1 –
Follow the steps given below to enable Exchange 2010 outlook anywhere –
1 – Open your Exchange server and log into it.
2 – Go to Exchange Management Console.
3 – Find Client Access under Server Configuration.
4 – Select your server and right-click on it.
5 – You will find Enable Outlook Anywhere. Click on it.
6 – Type your host name in the box.
7 – Select Basic Authentication.
8 – Click on the Enable button.
9 – The Completion screen will appear where you need to press the Finish button.
Method 2 –
1 – Open the PowerShell.
2 – Type – Enable-OutlookAnywhere -Server MBG-CAS01 -ExternalHostname ‘your domain name’ -DefaultAuthenticationMethod ‘Ntlm’ -SSLOffloading $False
