How To Enter Acer 5750g BIOS In Windows 10?
I need to make some virtualization changes on my laptop. I want to know how can I enter the Acer 5750g BIOS. I am using a Windows 10 OS.
You have two ways to enter the Acer 5750g BIOS.
Method 1
a. Turn off your laptop.
b. As soon as the Acer logo comes on the screen, press the F2 button.
c. Be alert when you try to do this; if you miss the chance, your PC will boot up.
d. The BIOS screen will come up.
Method 2
a. Click on the start menu.
b. Open Settings.
c. Open Update & security.
d. Go to the recovery tab.
e. Click on Restart now under Advanced Startup.
f. Select Troubleshoot.
g. Click on the Advanced options.
h. The Advanced options menu will appear.
i. Click on UEFI Firmware Settings.
j. Click on Restart.
k. The system will restart.
l. The BIOS screen will appear.
