How To Find Deleted Emails In Outlook To Recover Them
I have deleted some of the mails that were important from the outlook. Where can I go to find deleted emails in outlook and recover them without losing any data?
Recovering a deleted email can be a problem if you have deleted it from the trash folder only. It is then just not possible to get that email back.
But you have the file or mail in the deleted folder you can just easily go to that folder to find deleted emails in outlook, and restore them.
If you have by chance deleted the mail from the deleted folder also, then you have to go to the recoverable items, if you are lucky you will find your mail there. The mail comes in the recoverable items folder when you delete the mail from the deleted folder, else empty the deleted folder. But still, that is recoverable.
