How To Fix 0x0000001a Windows 10 Error?
I am suddenly getting a peculiar blue screen on my laptop with some text written. I do not understand what to do. Here is the picture of the error. How to fix 0x0000001a Windows 10 error?
There are several ways to fix 0x0000001a Windows 10 error.
Method 1 –
If you have recently installed software or upgraded your hardware, try uninstalling the software or removing the hardware. To uninstall the software, follow these steps –
a. Right-click on the start menu.
b. Click on Run.
c. Type “appwiz.cpl”
d. Select the program that you recently installed and click on uninstall.
e. Restart the computer.
Method 2
Use SFC to check for corrupted files in the memory. Follow the steps below –
a. Open Command prompt as Admin by searching in the start menu.
b. Type “sfc /scannow” and hit enter.
c. Wait for the process to complete and restart your device.
Method 3
Check for hard disk errors.
b. Type “chkdsk c: /f” and hit enter.
c. Restart your device after the process is complete.
Method 4 –
Try this out if your problem is not solved, by the methods given above.
Open the back cover of your laptop. Remove your RAM, clean it using an eraser, and plug it in again. Start your device.
Notifications
