How To Fix 0x0000001b Error In Windows 10?
am getting 0x0000001b error in Windows 10. Rebooting is not helping me. I updated my Windows 10, but it did not help. What else can I do?
You can try these methods to solve 0x0000001b error in Windows 10 –
Method 1 –
Use System Restore in Windows 10-
a. Type System Restore in the start menu and hit enter.
b. Choose a restore date on which your system was working correctly.
c. Click Next-> Finish completing the process.
d. Restart your device
Method 2 –
If you have recently installed software or upgraded your hardware, try uninstalling the software or removing the hardware. To uninstall the software, follow these steps –
a. Right-click on the start menu.
b. Click on Run.
c. Type “appwiz.cpl”
d. Select the program that you recently installed and click on uninstall.
e. Restart the computer.
